Software to use in migrating MS-Access to Oracle
Asked By 400 points N/A Posted on -
Just a simple question about migration of Microsoft Access database to Oracle database.
What software do I need to install on the same system as a Migration Workbench?
And where can I download that software and which version(if any) is better to use.
Answered By 0 points N/A #109725
The database that could help you in doing this kind of migration is SQL developer that is in SQL database. This is the only software that was developed to allow migrating that is importing and exporting of data in and out of the Oracle databases.
You can download the software from you PC and install it, because downloading  is free and installation is free do this from an SQL website.
The goodness is that it is free to download and install the database in you system without fear of licensing policies which may make downloading some software's hectic and expensive.
Try the SQL Server 2008 R2 Express and see whether it will be compatible with your system.
I hope this will be of much help to you.
