Software for video does not work
I’ve got a video and I am required to add additional vocals, particularly commentary to the video but I’ve got no idea how to do it. Thanks to Google as it suggested me to get hand on the mkvtoolnix software. Nevertheless, the time I clicked on the ‘mmg.exe’ it delivers the following error message:
"The application was unable to start correctly (0xc0000005). Click OK to close the application.”
Would anyone provide a solution?
Error:
sbaamui.exe – Application Error
The instruction at 0x062a8fc7 referenced memory at 0x062a8fc7. The memory could not be read.
Click on OK to terminate the program
Best Answer by Richwelle Boss
Answered By 0 points N/A #105950
You are getting this error message because your program is trying to access a memory that is not assigned to it.
The cause that makes the program attempting to access a wrong memory range can be anything; any bug or malware can cause this problem.
What you can try to do is:
  1. Run your program as administrator, an in compatibility mode with Win XP, you can do this by right clicking on the program and choose Property–> Compatibility.
  2. You can also try to uninstall your program and remove all the folders related to it, and reinstall it again.
Thank You
Answered By 0 points N/A #105951
Most probably reinstallinng after a system reboot will do you good. Just remove the entire setup and reboot the system and reinstall it once again and it might work. Still you can try unlimited number of video editors present in the market paid as well as freeware. Try some particular sites like filehippo or some other forum if you fail to find a particular software while on google.
