Software version Mac ftp import filezilla
The version which is compatible for Mac and stable also of filezila is 3.6.0.2. It's an open source for the FTP client. If you want to transfer the file and looking for the solution. It is the best option to use this program. It is Reliable, Attractive and updated every day. A quick look at the transfer interface is given to you. It is fast and can do huge transfers also.
Hello Amit,
If you have MAC operating system X 10.5 or later version then you should download the latest version of filezilla 3.6.0.2 (apple darwin9). It's minimum requirement is OS X 10.5. It is included with couple of new features that are:
1- The problem of stalling file transfer protocol over transport layer security is now fixed in the newer version
2- Better performance than previous versions.
You can download the compatible version with MAC by visiting the following link https://filezilla-project.org/download.php
Thanks
