Software for VGA performance improvement
Hello Techyv Users,
I am using Windows 7, I need have a software for VGA performance improvement, So that it improves the VGA game performance, Is there any such software, Please advise me in this regard, or provide me tips on improving the VGA game performance.
Thanks & Regards,
Lucien A Nieves
Answered By 15 points N/A #167486
Hi Lucien,
The tips for improvement of VGA performance are as mentioned below:
1) Check that the system has latest drivers installed in the system
2) Set the quality of audio and sound to reduce the use of hardware resources
3) If the user is using joystick, shut down the computer and unplug the joystick
4) Restart the system and test the game using keyboard
5) Disable the sound card by performing the steps as stated below
6) Click 'Start', Select 'Control Panel', Click 'System and security' option
7) Expand the 'sound, video, game controllers' section
8) Right click on the sound card and click 'Disable'
