A software that will allow recovery corrupted tar. The USB flash drive was corrupted together with mine .Tar files. Is there a way that we can recover those files; I haven’t formatted the USB flash drives yet.
When I open the flash drive the files are gone maybe the virus deleted or hide those files. I need your help.
Waiting for your support, thank you.
Hi There,
There's a software that allows you to recover files from corrupted memory card, USB flash drives and hard drives. It also allows you to recover files that are deleted due to viral infection or accidental formatting. Try “Zero Assumption Recovery”. For the procedure Unformat hard drive.
Hope this will help you.
Scan your Flash Drive first with your known good anti-virus for possible virus infection. Sometimes it also infected with the Trojan which has the ability to hide, rename or delete some files.
After scanning, Open your Flash Drive (for Windows 7) click organize and choose Folder and Search option, Window will pop out, click view tab.
Now you can see the Hidden files and folder, click with button Show hidden files, folders or drives and un-check those three hide settings just click yes to the warning. To unhide those files, right click the hidden files and click their properties and uncheck hidden.
