Software that will support PC game converter to PS3 disc
Is there any software that will support PC game converter to PS3 disk or is there any to change the format that will support the PS game in the PS3.
Wassup Head,
The query you have submitted here can partially be solved and I will try to help you as I can in this. The type of software that can be used in converting PC games to ps3 or vice versa should be none other than the ps3 tools.
These are items such as the disk image Generator, one you get it from the ps3 website, you can then proceed to download the software by following the prompts from the windows that appear on the display.
Once you install the software, trace it in the computer or on the launcher window, select 'Run' to start the software.
You can then add your file to the software and select 'Convert' to begin converting the software.
You need to change or adjust settings to make it be compatible with the size you require.
I hope this solves your query.
