Sofware PDF connexion security amazon security
Is there any way to improve security on the pdf that upload to amazon. I need to protect and lock the pdf files that I upload to the website.
There are many ways of protecting a PDF file. There are methods that can assure you of a secure protection and there are some that are only superficial. One method is by using Adobe Acrobat. Using this you can open the PDF file, add password and maybe set an expiration period for the file then save it again. You will then have a new file protected with password and or an expiration period implemented.
You can also put your PDF file inside an archive and then password-protect it so only those you know and share it with can open the file. Generally, the best way of protecting your PDF file is to not share it publicly to prevent unauthorized access to the file. Share it only with someone you know or to members of a group. You may also read this helpful information to give you a better idea: Answers™ — How to protect a pdf file?
Notifications
