I recently bought a portable air conditioner from soleus. It works fine most of the time, but then it sometimes throws this soleus air conditioner h8 error. Unfortunately, I misplaced the manual and do not know where to go with it. Can you direct me as to what to do when this happens?
Soleus Air Conditioner H8 Error Portable Air Conditioner
Recent times have seen a rise in popularity of portable air conditioners and Soleus is one of the most popular brands. Much like many modern electronics, these air conditioners use error codes to relay the different problems that the device may be encountering.
In this case, the h8 error code signifies the water reservoir is full. So basically, stop the water supply when this code occurs. The easiest way to deal with these is to download an online manual. You will find the manual for your air conditioner easily since it is a popular air conditioner.
