From time to time I use the 3D CAD software SolidWorks to create some designs for my dream-house. The last time I tried to open SolidWorks, I got the error below. Since I did not know what to do, I decided to reinstall it but I still have this problem.
SolidWorks
Operation failed due to geometric condition
Solid Works Operation Error has occurred
The problem can be caused by several things. Check the following please:
1. Look for zero thickness geometry or touching edges.
2. Try tools>check and do a stringent solid/surface check.
3. Run import import diagnostics on imported parts.
Hope this can trace you to the problem.
Hi John J Houston,
Your problem might have arisen from incompatibilities with the version of 3D CAD software SolidWorks installed in your computer to your operating system. Either the program or the system is outdated. Here's how you fix this:
1. Install the latest system updates available.
2. Uninstall 3D CAD software SolidWorks and then install The latest version available.
3. Restart your computer and try using the program.
Hope this works.
Murakami Wyatt
