Solid Works; Warning message. File from educational version…
I downloaded chapter examples and end-of-chapter problems from SDCpublications.com, when I opened the problem files using SolidWorks this error came out.
What is the fix for this?
Solid Works
Warning: The file… is from educational version. This file is for instructional use only.
Answered By 30 points N/A #164850
The files which you have downloaded from SDC publications.com are the copyrights of SDC publications.com only and no other person outside SDC publications.com can use those files.
That’s the reason you got an error while trying to open those files. If you need the files at any cost the contact SDC publications.com for the material. These files are encrypted and the only way is to contact SDC publications.com for your required files.
Thank you.
