Solidworks Enterprise PDM error empty value
can anyone please tell me why does the following error message occur while using Solidworks enterprise PDM? Can someone tell me what should I do to get over it?
SolidWorks enterprise PDM An empty value is not permitted for variable ‘PartClass’.
Answered By 10 points N/A #151058
Dear Warren Donaldson,
SolidWorks Enterprise PDM requires a value for its variable, although all of the variables need its value to run. If you don't use it, your required task can't be done. You have to put a value in your variable to make your work run smoothly and do it perfectly. I think you won't ever face any problems if you use the value in the variable.
Thank you,
Lesliez Mark
