SolitairePlus.exe – Illegal System DLL Relocation
I am just hoping that I get a solution for this problem here. I purchased a software application called SolitairePlus and had it installed and running on my machine from past a few months.
I had not been using that individual machine for some time and now when I try to open the application it gives me an error message
The system DLL user32.dll was relocated in memory. The application will not run properly. The relocation occurred because the DLL C:WINDOWSsystem32hhctrl.ocx occupied an address range
reserved for Windows system DLLs. The vendor supplying the DLL should be contracted for a new DLL
Now why is it coming with this error and how to solve the same?
Best Answer by Bryan Miguel
Answered By 0 points N/A #114666
It is common error due to Microsoft Security Update. There is a file rthdcpl.exe which is used by sound cards. There is a simple solution.
Go to Microsoft Support
Download Update for Windows XP (KB935448)
Install run.exe
Or the simplest way is delete the current version of your sound driver and download the updated driver for your sound card and install it in your system and reboot your system.
And you can also try and install fresh copy of solitairePlus.
See if the problem is solved. Good Luck!
Answered By 0 points N/A #114668
This problem occurs when the following third-party applications are installed:
• Realtek HD Audio Control Panel
• ElsterFormular 2006/2007
• TUGZip
• CD-Tag
So if you have one of these applications, that's probably one of the main reasons why you are getting that kind of problem.
The easiest solution is to uninstall the third party application. Or you can download the file I have given you below:
http://www.microsoft.com/en-us/download/details.aspx?id=24529
