Solution Center HP C7280 Error Message While Scanning Computer Or Software
Hello guys
I make an attempt to scan with Solution center to HP C7280. All are present on Windows 7 operating system virtual engine on an iMac.
Hello guys
So you are running your Windows 7 on a virtual machine which is installed in your iMac. Maybe that’s the reason why you are having problems using your HP printer/scanner because the device can detect both of the operating systems.
I’m not sure if you still need to install your HP printer/scanner on Windows 7 which is in a virtual machine while you are already using an iMac. Why not just install the HP printer/scanner on your iMac and not on Windows 7 to avoid the confusion in the application.
Since your HP Solution Center is already not working well in both of the operating systems you have, try uninstalling this application on both operating systems. After this, check your computer for any possible errors. Use a disk utility application to check the system. Install the software on the iMac again after this and then check if this fixes the problem.
To find a different solution to this problem, you may visit here.
