Solution for damage jpg file
My flicker account contains some damage jpg files which are not displaying result. How can I repair these files to make visible?
There is software known as ‘Stellar Phoenix JPEG Repair’. It is quite efficient in repairing the broken files specially jpg type files. The quality of restored file remains same as the previous time. You can use a trial version of this software. If it proved successful for your work, you may buy the full version. Visit: https://www.stellarinfo.com/jpeg-repair.php.
Hi Jeo,
Please download a JPEG recovery tool. You can either use JPEG Recovery or Picture doctor.
Once you installed the recovery program, open the corrupted JPG file using File menu.
Click on the recover button and see how the recovered picture image. You may need to try another tool if the picture is till corrupted.
Repair Corrupt JPG Files is a free shareware version you can try if you are still unsuccessful with the other two.
Thanks!
