Tania
Posted on - 11/19/2012
I recently downloaded the AVG anti virus software. Now I receive a message saying there is a Fanta tune Avg threat arising out of my Fanta tunes media player. I really don't want to remove my player. What should I do? Should I ignore it?
Help needed.
Solution for a Fanta tunes avg threat?
Hello Tania,
You may consider observing your computer system for 1 day and see if you are having problems with your files. If not Then there is no such thing as the threat or virus it is just a false positive. Sometimes antivirus detects viruses into programs especially when their scanning setup configuration is more than at a normal level (Check your antivirus configuration settings).
If you noticed something's wrong with your system like it often times Not Responding or crashes. You may have to uninstall the Fanta tunes and reinstall it using the latest  version of the software.
Hope this two simple method helps you.
