Solution For 0x800701e7 Error Code
Today, I was trying to update the windows installed on my PC. I downloaded it, and when I installed one of the service packs, this 0x800701e7 error code starts appearing on the screen. I never received this error before so, I canceled the process and again tried to download it but faced the same error again. Is there any method to fix this error manually?
Answered By 0 points N/A #325722
This 0x800701e7 error indicates that some file is missing in your recent update. You can use these steps to fix this error manually-
  • Click on the ‘Start’ button.
  • Type ‘Regedit’ in the search bar.
  • Click on ‘HKEY_LOCAL_MACHINE.’
  • Click on ‘Software.’
  • Select ‘Policies.’
  • Click on ‘Microsoft.’
  • Click on ‘Windows.’
  • Select ‘Windows Updates.’
  • Click on ‘AU.’
  • Select the ‘delete’ option in the AU folder.
  • Click on the ‘OK’ button.
  • Reboot the PC.
If the above steps are not fixing the error, then try these steps-
  • Click on the start button.
  • Type ‘services.msc.’
  • Press the ‘Enter’ button.
  • Click on ‘Update services.’
  • Right-click on the ‘Windows Update services.’
  • Click on ‘Stop.’
  • Click on ‘Ok.’
  • Reboot the ‘PC.’
Answered By 590495 points N/A #326314
This error code “0x800701e7” appears, most of the time, in Xbox One. If you see this in Microsoft Windows and it is preventing the computer from working properly, try booting the computer using the last known good configuration option. Start or restart the computer then press F8 before the Windows logo appears. In “Advanced Boot Options” screen, scroll down and select “Last known good configuration” then hit Enter.
If this doesn’t work, try using the System File Checker utility. Press the Windows key + R to bring up the “Run” dialog then type without quotes “sfc /scannow” then hit Enter. Insert your Windows setup CD or DVD on the optical drive when you are prompted then continue. Wait until the process is complete. When it is finished, restart the computer.
