Solution For How To Put Copyright Symbol In Word
I want to know the method on how to put copyright symbol in word on the document. If anyone has any idea how to do so then please help me as it’s really important. Thank you.
To insert copyright symbol-
You can try any one of these and it will definitely work.
In Microsoft Office Word, inserting the copyright symbol in your document is easy. You can insert the symbol either using your keyboard or from the Insert menu in Microsoft Office Word. To insert the copyright symbol from the menu, in Microsoft Office Word, select “Insert” tab then click “Symbol” on the upper right corner of the screen to bring down the dropdown list.
Select the copyright symbol from the list and the symbol should then appear on your document.
To insert the symbol using the keyboard shortcut, position your cursor where you want the copyright symbol to appear then press CTRL + ALT + C and you should see the symbol on your document.
