Solution for ‘hp 8710 is offline’ error is continuously occurring
Asked By 96110 points N/A Posted on -
Hi, I have this Hp 8710 OfficeJet Pro printer. When I connect it to my router and try to use it, on the printer, it says that connected but on the computer, it keeps displaying ‘hp 8710 is offline.’ How to fix this error?
Best Answer by
Answered By 0 points N/A #320717
It is happening because of some technical fault occurring between two devices that are trying to communicate on the same network. Firstly, do a quick scan on your computer using the security system you are using. Now connect your printer with your router. Now, download HP OfficeJet Pro 8710 Drives.
After this, uninstall the printer from your PC and after that try re-installing it. Do not forget to restart your PC. After all these steps if still ‘hp 8710 is offline’ error keeps displaying then there must be some issue with computer files or software. In this case, contact ‘Hp Printer Support.’
