Solution For Play Roller Coaster Tycoon 0xc0000142 Error
I wanted to play roller coaster tycoon on my computer as I was trying some old games. But everytime I insert the disk and try to play it, I get the error 0xc0000142. Need help.
To fix the problem-
Solution-2
You need to keep the disk inserted
If you want to play “RollerCoaster Tycoon,” check the system requirements first before installing and make sure your computer meets those requirements. “RollerCoaster Tycoon” supports Windows XP and Windows Vista. It requires 1.8 GHz or faster processor, 512 MB RAM, Microsoft DirectX 7-compatible video card, and 2 GB free space. If you have Windows 7, try running the game in compatibility mode for Windows XP or Windows Vista.
Right-click RollerCoaster Tycoon then select “Properties.” In the properties window, go to “Compatibility” tab then check “Run this program in compatibility mode for” under “Compatibility mode” section. Select a version of Windows XP or Windows Vista from the dropdown list then click “OK.” Start the game then see if it works. If this doesn’t work, repeat the same steps and go back to “Compatibility” tab.
Under “Privilege Level” section at the bottom, check “Run this program as an administrator.” Click “OK” then see if this helps. For more information about the game and to download it, go to RollerCoaster Tycoon: Deluxe on Steam.
