Solution For Windows Installation Error 0x80070017
I am repeatedly getting the Windows installation error 0x80070017 and I am unable to find a fix for it. I can’t install Windows because of that. People please help me with this.
To fix the error-
This will fix the error.
You may receive error code “0x80070017” in two cases: one, when you are trying to install Microsoft Windows, and two, when you are trying to install an update or Windows Update on your computer. If you receive the error when installing the Microsoft Windows operating system, it means you are probably installing from a DVD drive.
If this is the case then the problem is because of the inability to read some files from the DVD disc. One possible cause is a damaged or unreadable disc. To go around the problem, perform the installation from a USB flash drive. If you don’t like installing Windows from a USB flash drive, the last option is to burn the image or the ISO file on a blank DVD disc or DVD-R.
On the other hand, if you receive the error when installing a Windows Update, try doing this. Click “Start,” “All Programs,” “Accessories” then right-click “Command Prompt” and select “Run as administrator” to start an elevated command prompt. In the command prompt window, type the following commands then hit Enter after every command:
net stop wuauserv
cd %systemroot%\SoftwareDistribution
ren Download Download.old
net start wuauserv
After this, install the Windows Update again and see if it works.
