Solution For Windowsupdate_800f0922 Error Message
I’ve been getting a windowsupdate_800f0922 error while trying to update three windows updates. I’ve tried several times but no hope. Is there any fix to this problem?
Kindly follow these steps:
• Firstly, turn the anti-virus temporarily off.
• Now, try running the windows update troubleshooter.
– To run the trouble-shooter press windows key + w.
– Type the word troubleshooting in the search bar.
– Click on view all
– Go to windows update and follow all the prompted steps.
• Or else, try installing the update in clean boot mode.
• If none of the above methods worked, try installing the updates from the Microsoft’s website by searching the name of the update you were receiving.
