Solution For Wlan Autoconfig Error 1068 Problem
I need help fixing the wlan autoconfig error 1068 while connecting to the internet via my router. I haven’t found any fix for this. Guys please help.
To fix this-
This will fix the error.
This problem can happen if the service is corrupt. To try fixing the problem, click “Start” then in the search box type without quotes “regedit.exe”. Right-click on “regedit” then select “Run as administrator.” Navigate to this location:
Double-click “Start” on the right then change the value to 2.
Close the registry editor window then restart the computer. See if it works. If this did not work, take a look at this fix: Unable to start WLAN AutoConfig. You must have a Microsoft account to download the “EAP.txt” file.
