Solution Of 0x000007b Error In Windows 10
I am trying to run a video game on my Windows 10, but the application is unable to run. It gives me a 0x000007b error. How to fix this?
There are several methods to fix 0x000007b error.
Method 1Â
Check whether the game is compatible with your Windows Architecture.
a. Right-click on This PC.
b. Select Properties.
c. Since you are using Windows 10, there is a high chance you have 64-bit OS.
d. Check whether your game is compatible with 64-bit OS or not.
Method 2Â
a. Search for Apps and Features in the start menu.
b. Find your problematic app and click on it.
c. Click on Advanced Options.
d. Scroll down and click on Reset.
e. Rerun your game.
