Solution Of 0x0501 Steam Error
Hi, I am using Steam for my Windows PC, and recently, I encountered a 0x0501 error. The applications shut down automatically. How to fix this?
Try out these methods to fix 0x0501 error –
Method 1- Reinstall Steam:
a. Press Windows + r.
b. Type appwiz.cpl in the input area and press enter.
c. Click on the application that is causing a problem.
d. Uninstall the application.
e. Install it again.
Method 2-
b. Type cmd admin in the input area and press enter.
c. In the command prompt, type DISM.exe /Online /Cleanup-image /Restorehealth and press enter.
d. Wait for the process to complete.
e. Now, type sfc /scannow and press enter,
f. Wait for the process to complete.
g. Restart your computer.
One of the above two methods will solve your problem.
