Solution Of Error Code 0x851a001a Generating During Installing SQL Server Express 2019
While installing SQL Server Express 2019, this ‘error code 0x851a001a’ is continuously occurring on the screen. How can I solve this problem regarding the installation of it?
Answered By 10 points N/A #321773
While installing SQL Server Express, to avoid ‘error code 0x851a001a’, make sure that-
• You should always try to install it by using the account with Local Administrator rights.
• You should check that your machine must not be a Domain Controller.
• Always select the ‘Update’ option if the update or not pop up appears on your screen after installing it because if you select the ‘Not’ option then, the installation will fail.
Follow the steps given below to download SQL Server Express 2019-
• Visit this link
• Select ‘Download now.’
By this, you will get set up as ‘SQLServer2019-SSEI-Dev.exe.’
To install SQL Server Express 2019-
• Double click on ‘SQLServer2019-SSEI-Dev.exe.’
• Now, in appearing options choose ‘Basic.’
• Select ‘Accept’ on the following ‘Microsoft Server License Terms’ screen.
• Wait till the downloading is occurring.
• Now, the installation process will proceed.
