Solution to rant powers down when i slide shut
I have had my Samsung Rant for about 4 years now and I never had a problem with it ever since. Nowadays, my rant powers down when i slide shut. I thought it was only a coincidence but it kept happening and the occurrence is already becoming more frequent. Could there be a quick fix to this problem of mine?
Answered By 0 points N/A #159507
Hi Ashley,
Its not a big issue I also face same problem before few month's back  in this type of case mostly there are two main problems are expected with phone
1: Phone software
2: Battery
First of all check your battery some time the battery is working properly but there is some problem with phone hardware suddenly or when you perform any action the cell get off, Second main reason is with software reinstall your cell software and you will never face this problem again, I had given you two options because you didn't given your set model number.
