I receive error message 0x8024a10a when my MacBook Professional attempts to update Windows 10. The update takes a long time, so it is blocked at seventy-five. I am always joined to a fast broadband service. This is extremely frustrating because it generates this error message and indicates that it should help with Microsoft technical support.
However, we tend to come back here and there is no solution! After a while, the update will be retried and the same problem will occur. At this rate, my computer does not get the Windows updates that it wants and a lot of my time is lost. A set of circumstances must be programmed to inform it of this error code! Please facilitate with a solution!
Solution To 0x8024a10a
We recommend that you simply run Windows Update Repairman. A clean boot would also help the US solve this problem. Therefore, try to perform a clean boot after restarting the PC. Here is a way to.
Look for msconfig from the beginning.
In the search results, select System Configuration.
On the Services tab, in the System Configuration area, select or click to select Hide All Microsoft Services, and then select the Disable All check box.
On the Home tab of the system configuration, open the task manager.
On the Home tab of the Task Manager, for each startup item, select it, and then click Disable.
Close the task manager
On the “Start” tab of the system configuration, click “Tap” or “OK” and restart the PC.
Once the reboot is complete, you can try to upgrade Windows 10 at this point.
