Solution To Check Windows Update Status Given
I am looking for ways to check Windows update status on my PC and install new updates. I have just started using a Windows laptop and I need help with this.
To check your wondered update serious-
1. Proceed to settings in your pc
2. Then go to update and security
3. Choose Windows update and there you will see the pending updates and what are they related to
4. If your pc is up to date it will be mentioned as that.
5. If not then install the latest updates
If it’s your first time to use a computer or a laptop and wondering how to check for updates in Windows 10 and install them, on your desktop, click “Start,” “Settings,” “Update & Security settings,” and then “Windows Update.” Here, click on the “Check for updates” button. If any updates are available, you will see them here.
On the other hand, if Windows Update says that your computer is up-to-date, that means all available updates have been installed on your computer. If a Windows Update is available and you want to know more about the latest update, just click on the “Details” link. All additional information about the update will then be displayed.
