Solution To Error 0x8007048f
My computer is recently receiving an error which is 0x8007048f error I have tried a lot of solutions, but I can’t get rid of this error what should I go to resolve this error?
Error 8007048f occurs when you are trying to update your windows; it is a very fundamental and regularly occurred error. There are various manageable ways in which you can retaliate this error.
Solution 1: you can use Windows Update Troubleshooter.
Solution 2: Disable anti-virus
• Sometimes your anti-virus can also be the reason that you are getting this error so disabling your anti-virus can just fix your problems.
Solution 3: Run SFC scan
• It is possible that this error might occur because of corrupt files in your system, so run an SFC scan for it. For that open the command prompt and type the command SFC/SCANNOW.
