Solution To Error Code 53 In Microsoft Windows.
Hi everyone, from the last few days my System is running into a problem. Whenever I try to launch a particular application my system initially freezes and then the application stops working and a window opens with error code 53.
Kindly help me with this issue.
Answered By 0 points N/A #304310
The error code 53 is mostly because of the improper working of the directory setting of the application.
Select Start, type show hidden files and folder and press enter.
In the check box, select the option to show the hidden files and folder.
Now open the folder where you earlier tried to install the application and cut the folder and paste it in your user name folder.
Run the application after rebooting the device.
