Solution To The Error 0x000000a5 Is Quite Simple! Is It?
Hey, Guys! I recently encountered this 0x000000a5 error message while starting my computer. Can anyone tell me what could have caused it and how to fix it?
A) This 0x000000a5 error you might face while installing the Windows XP on your system and the BIOS of your computer is not fully compliant with ACPI. To fix it, you need to follow these steps:
1. Restart your computer to the windows setup and run it once again.
2. And when the setup begins to start up again, press the F7 key, and the Windows will automatically disable the installation of the ACPI HAL and installs the Standard PC HAL. It will solve your issue.
B) This 0x000000a5 error is quite normal while you are trying to install windows, and sometimes it fails to copy the files in the system. As a result, you will see this error.
To fix it, you need to update your BIOS and your motherboard to the latest version to resolve it.
