zenith keen
30 points
Posted on - 08/31/2012
Hi Experts,
I am seeking a solution for wireless console utility win 7.Now I have encountered a serious issue with wireless console it get stuck when I open it.Sometimes it automatically get shut down.Can anyone solve this issue providing suggestions.Thanks.
Zenith Keen
Solution for wireless console utility win 7 ?
Hi Zenith,
I think you should update your wireless console utility software driver.
As you are using windows 7, enabling the automatic update of Win 7 may be helpful to update your software.
You can also manually download the updated software from the Internet and install the updated software.
I hope it will solve your problem.
LyanaHay
Hi Zenith,
 I think I can help you in this topic, you mentioned that your utility sometimes get stuck in middle of somewhere and becomes unresponsive.
I will suggest to perform following things which will help you to solve your problem:
1] Make sure your utility driver is updated.
2] Check whether your Wi-Fi drivers are up to date.
3] Try reinstalling utility software
