Solutions For What Are Windows Log Files In Stepwise
Hello, brief for what are windows log files and also notify the steps for reading too and thank you for the solutions as well.
Hey, Â what are windows log files normally deals with the logged file in the specific folders where there are many log files kept. The same maintains the record for it as well and also goggles the same for the auto updates if required. Below shows the steps for reading the same:
The Windows log files you are referring to is the Windows Event Viewer which is part of the Microsoft Management Console. It is a component of the Microsoft Windows operating system in the Windows NT line of operating systems that allows users and administrators view the event logs on a local computer or remote machine. The Event Viewer lets you monitor events in your system.
The Event Viewer maintains logs about applications, system, and security events on your computer. You can use it to view and manage the event logs, collect information about software and hardware problems, and track security events. The Event Log service starts automatically with Windows when you start the computer and all users can view system and application logs.
In Windows Vista, Microsoft overhauled the event system because the Event Viewer’s routine reporting of minor startup and processing errors, which don’t in fact harm or damage the computer, is frequently used by technical support scammers to convince or persuade users who are unfamiliar with Event Viewer that their computer contains critical errors requiring immediate technical support.
