Solutions To Server Error On Google Play, Now Can Be Solved With These Steps!
Hey, Guys! I was recently using my mobile then, I suddenly encountered this error, “server error on Google Play.” Can anyone help me solve this error?
A) – One of the reasons it could have to happen that you might have a problem with your wifi connection that you are using. To fix this, server error on Google Play follow these steps:
1) Turn off your Wi-Fi, and then after some time, maybe after 2-3 minutes later, turn on your mobile data.
2) Then, you can try to access it, after some time to see if it has fixed your problem.
B) – If this didn’t work, you could try this method to solve, server error on Google Play, to solve the error:-
1) Go mobile Wi-Fi setting and long-press the Wi-Fi connection that you are using. Then, choose to forget the connection option.
2) Now, go to your router and unplug it and restart it.
3) Now, go to your mobile and then reconnect to your Wi-Fi network after it has restarted.
4) Now, try to access Google Play. Your problem should have resolved.
