Tiongco Xone 0 points N/APosted on - 06/30/2017
I love playing computer games on my PC. I was playing Call of Duty, and suddenly the system showed a message saying Call of Duty has encountered an unrecoverable error. How can I solve this Call of Duty DirectX error?
Before installing the game “Call of Duty: Advanced Warfare”, make sure your computer meets the requirements. The game supports Windows 7 and Windows 8.x all 64-bit. Microsoft Windows 10 is not officially supported.
It requires 2.93 GHz or faster Intel Core i3-530 or equivalent 2.60 GHz AMD Phenom II X4 810 processor, 6 GB RAM, Microsoft DirectX 11-compatible video card with 1 GB video RAM (NVIDIA GeForce GTS 450, ATI Radeon HD 5870, or better), 55 GB free space, sound card, and broadband internet connection.
Since the error caught was obviously from Microsoft DirectX and it was triggered right after you run the game, check if you have the required Microsoft DirectX version. To check, click “Start” then type without quotes “dxdiag” in the search box. Click “dxdiag” from the results and check what version you are using on the first page.
If you are using either of the supported operating systems then I don’t think you will have a problem with Microsoft DirectX because Microsoft DirectX 11 is included in both operating systems. You probably need to check your video card for compatibility because I think that’s causing the problem. Try upgrading your video card because the game has a high requirement on this part.
The game “Call of Duty: Advanced Warfare” is a first-person shooter game developed by Sledgehammer Games and Raven Software published by Activision released on November 3, 2014.
1....
