I sent several wab files to my friend who is using mac via e-mail as attachment. He told me that he couldn’t open those files and then I suggested him import them to outlook. Again he failed and please tell me can't mac open/import wab files using outlook? I am using windows and I have no clear idea about those mac outlook wab files. Thanks
Solve this problem about Mac outlook wab files.
First of fall to tell you that Mac is not compatible with the .wab files. So it won't open these files for you. There are some solutions by which your friend can try to open these wab files. Giving you the solution step by step choose yourself which one is best for your friends.
1. Go to http://www.zamzar.com. Its online service to just convert these wab files to .Doc files.
2. You can use the software to change these wab files to other formats.Â
Here is the URL to download the softwareÂ
http://www.littlemachines.com/
