Solved Application Error 0x0000005 Startup Problem
I want fix for the application error 0x0000005 that I am facing while trying to access some programs on my computer running Windows. People please help me solve this.
To fix the problem you are facing-
Then you can get back to connecting to the internet and you will find the error fixed.
Error “0xc0000005” is also called “Application Error“ (Access Violation). You receive this because your computer is not able to completely process the files and settings it requires to run a specific application or installation. This error is caused by many different causes like faulty memory modules, errors in files, and problems with the settings of your computer.
There are many ways to fix this and one is to restore your computer to a previous state. Click “Start,” “All Programs,” “Accessories,” “System Tools,” and then “System Restore.” Select an older restore point then see if this fixes the problem. Another way is to fix problems with the Windows registry. Download PC Tools Performance Toolkit then follow the instructions to download and unpack and then install it.
Once installed, start PC Tools then go to “Performance” tab and click “Clean Your Registry.” Make sure “Complete Registry Scan” is selected then click “Start Scan.” Wait until the scan is complete then repair them. You can also use CCleaner to fix problems with the registry. Go to CCleaner Download then download the free version. Select “Registry” on the left pane and click “Scan for Issues.”
After the scan, click “Fix selected Issues” to fix all the problems found. After this, restart your computer.
