Solved Application Error 0xc00007b Problem
I want fix for the application error 0xc00007b startup problem when I try to open some game or program on my PC. Please people help me with this problem.
![](https://www.techyv.com/sites/default/users/Images-Folder/0xc00007b-error-300x105.jpg)
This problem could be because of multiple reasons-
One of the above methods will definitely solve the problem.
That is a typical glitch that usually happens to programs during startup. The cause can be anything. Just click “OK” to exit the dialog then start the application again. If this doesn’t work, restart your computer then disable your antivirus temporarily after booting and then run the program again. See if this works.
If this fails again, check the system requirements of the program and make sure you did not miss installing something. Some applications require Microsoft .NET Framework. Check if your program needs installing this and then install it. If your computer meets the requirements and you haven’t missed installing anything, try reinstalling your program. Go to Revo Uninstaller Download and download the free version.
Once installed, start Revo Uninstaller then select your program in error on the list. Click “Uninstall” then follow the instructions to completely remove everything the program created on your computer. When it is finished, restart your computer then go to CCleaner Download and then download the free version. Once installed, start CCleaner then clean your system.
After this, install your program back and all its components if there are any and then try running the program again. If you want to convert CCleaner to Pro, just download the codes and follow the instructions.
