Solved Compile Error In Hidden Module
“Compile error in hidden module” this error message pops up whenever I am trying to work on MS Word and MS Excel. Help me, please.
It happens when the Office user opens MS Word or MS Excel. Here are some steps you perform that might fix the Compilation in hidden module error.
• Update Adobe Acrobat.
Open Acrobat > Click Help > Check for updates. If updater window opens press Download and Install button.
• Change the location of the pdf maker.
Press Search option > type Pdfmakerr.dot in search option > Open file location by right-clicking the file > right-click the file and select cut > go to the position where you want to paste it.
• Register OCX Files with the command prompt.
In windows, it can also be a glitch of windows update.
Press the Window Key + X hotkey > Tap on Command Prompt (Admin) > For 32 bit users input the commands
regsvr32 -u
c:windowssystem32mscomctl.ocx
regsvr32
For 64 bit users
regsvr32 -u
c:windowssyswow64mscomctl.ocx
regsvr32
• Uninstall/Update the Norton Antivirus Software.
