Solved Dxerror.log And DirectX. Log Error Problem
I need solution for dxerror.log and DirectX. Log error problem I am having while trying to play some games in my PC. I have been getting this for some days now. People please help me fix this.
To fix the error-
This will check for problems with system files. This should fix the error.
If you have a problem with Microsoft DirectX, one way of fixing it is to upgrade the version you have. If you have Microsoft Windows XP, the latest version you can upgrade to is Microsoft DirectX 9.0c and this is for Windows XP and Windows Server 2003.
If you have Microsoft Windows Vista, it ships with Microsoft DirectX 10 and you can upgrade to Microsoft DirectX 10.1 or Microsoft DirectX 11. Microsoft DirectX 10.1 requires Windows Vista Service Pack 1 or higher and Windows Server Service Pack 1 or higher. Microsoft DirectX 11 requires Windows Vista Service Pack 2 and Windows Server 2008 Service Pack 2.
If you have Microsoft Windows 7, it ships with Microsoft DirectX 11 and can be upgraded to Microsoft DirectX 11.1. Microsoft DirectX 11.1 requires Windows 7 Service Pack 1 and Windows Server 2008 RS Service Pack 1. To upgrade Microsoft DirectX, visit How to Install Latest DirectX.
Notifications
