Solved Framework 4.5 For Windows 7 Installation Error
I am looking for fixes for Framework 4.5 for Windows 7 installation error which I keep receiving while trying to install it in my PC. I have tried multiple times. Guys help me fix this.
The given methods may help you fix this problem-
1. Run your PC in clean boot mode as this will help you find any issues related to third party software
2. You can also try using the system update readiness tool to fix this and your will have to download this.
3. Run the command sfc/scannow in command prompt to check for problems
One of the above should definitely fix the problem in your pc and help you install framework 4.5 in your Windows 7 PC.
You received that error because your computer doesn’t meet the requirements. Your computer’s specifications probably passed the hardware requirements of the application but there is a missing component required by the program that you forgot to install. You should install it first prior to installing the main application.
Before installing any application on your computer, make sure your computer meets the requirements and all required components must be installed first. Autodesk Product Design Suite 2016 supports 64-bit Windows 7 Service Pack 1 and Windows 8.1.
It requires 2 GHz or faster 64-bit Intel or equivalent AMD processor, 8 GB RAM, 100 GB free space, Microsoft DirectX 10-compatible video card with OpenGL 3.0 support, 1280 x 1024 screen resolution, Microsoft Internet Explorer 10 or higher, Microsoft .NET Framework 4.5 Service Pack 1, Microsoft Office Excel 2007, and USB 3.0. To fix the error you received, simply install the required version of Microsoft .NET Framework.
Download Microsoft .NET Framework 4.5.1 or Microsoft .NET Framework 4.6. Once this is installed, restart the installation for Autodesk Product Design Suite 2016. This should fix the problem.
