Solving 1038 Source File Not Found
When I try to perform a major installation of Microsoft Windows System Resource Manager (WSRM) by sacrificing the Microsoft Windows Installer package for WSRM, I fail. When I try to create the WSRM Executive installation package for network installation by using the msiexec / a Path command: \ wsrm.msi, you receive the following error message “1038 source file not found”. How can I fix this?
Answered By 0 points N/A #322247
A supported fix is ​​from Microsoft on the market. Apply this hotfix only to systems that have this specific problem. This hotfix may receive additional tests. If you are not serious about this inconvenience, we usually recommend that you simply wait for a later software update that includes this hotfix. If the hotfix is ​​on the market for the transfer, see the “Available Hotfix Transfer” section at the top of this article in the database. If this section does not appear, contact Microsoft Technical Support for the fix.
Answered By 590495 points N/A #328444
If you are installing EZdrummer and you encounter this error, make sure you are using an admin account. It won’t install on limited or non-admin user accounts. If you don’t have an administrator account, ask someone with an admin account on the computer to install the program for you. If this is not the problem, check the system requirements and verify that your computer meets those requirements.
EZdrummer supports Windows 7, Windows 8.x, and Windows 10. It requires Intel Pentium 4 or equivalent AMD Athlon or faster processor, 2 GB RAM, 4 GB free space, and professional sound card recommended. For Macintosh, it supports macOS 10.6 Snow Leopard, 10.7 Lion, 10.8 Mountain Lion, 10.9 Mavericks, 10.10 Yosemite, 10.11 El Capitan, 10.12 Sierra, 10.13 High Sierra, 10.14 Mojave, and 10.15 Catalina.
It requires Intel-based Macintosh with 2 GB RAM. If the problem continues, try downloading EZdrummer again or get the latest EZdrummer 2 on the home page.
