Solving 800f0902
I keep trying to get the latest updates and they fail. The update history shows error 800F0902 for all the latest updates. It happened a moment. Will someone be in terribly simple/precise words to solve this problem?
You can try running the System File Checker (SFC.exe) and see if the problem persists. To do this, follow these steps
1. Open Associate in Nursing for sophisticated electronic communications. Click “Start”, “All Programs”, “Accessories” and right-click on “Electronic Communication”.
Then click on “Run as administrator”. If you are prompted to enter a positive identification as a partner in the nursing administrator or confirmation, enter the positive ID or click on permission.
2. Enter the following command and press Enter:
sfc / scannow
