Solving Bugcode Ndis Driver
Today, after turning on my laptop, it crashed while Windows was loading. I saw this error: BUGCODE NDIS DRIVER BSOD. I am using a Windows 8 laptop. Please help me repair it. thank you.
If the error appears when you enter a specific driver, you can uninstall that driver through Device Manager. Here’s a way to do this:
Press the Windows + X key and click Device Manager.
Click next to a tool class to expand it.
You can now reset the driving force by right-clicking and clicking Properties.
Go to the “Driving Force” tab and click on “Rollback Driver”.
If that does not work, you can right-click the driver you want to disable, and then click Disable.
If this stops crashes, you will need to install the new driver from the manufacturer’s website to use the device. This problem may need to be resolved by updating the replacement driver.
