Solving Error Code 051030 In Nintendo Wii.
I am unable to make my Nintendo Wii online as it is showing Error code 051030, how to make it online and how to fix this problem.
There are some reasons why is it showing the error code 051030 all of them are related to your router. If you are using a wireless router, then you need to change the settings, or you have to power cycled the router.
Methods to fix the router:
1. Restart your router’s redo the settings and then connect it to Wii and retry again.
2. Delete the old connection and then set up a new connection and try to connect again
If the above step does not resolve the problem then click on the link given below
support.nintendo.com/errorcodecontact
