Honestly, I thought this laptop could not be worse. I downloaded the latest version of the PS Support wizard after installing Windows with all other PS components. The wrong language “HPSF.exe does not work anymore” from there, it continues to jump every time you start the support wizard. Can anyone provide me the solution of this hpsf error?
: Solving Hpsf Error
This problem may occur if the system file system unit is corrupted. I advise you to uninstall the Power Wizard and see if it solves the problem. Follow the steps to uninstall the Power Assistant:
Press the Windows + X key and click on the dashboard.
Click Programs and Options and select the Power Supply Support Wizard.
Right-click on it and uninstall it.
Restart your computer after uninstallation is complete.
Now, I advise you to transfer the latest version for your IT support assistant
The full error reads:
“HPSF.exe has stopped working
This application has encountered a serious problem and must close. Click “OK” to automatically restart this application.”
This problem normally happens when opening updates from HP Support Assistant and clicking “OK” doesn’t restart the application. To fix the problem, uninstall the current version and install the latest. Download the free version of Revo Uninstaller and install. Once installed, start Revo then select HP Support Assistant among the applications and click “Uninstall.” Follow the normal uninstall process.
When you are prompted to restart the computer, click to restart later. When uninstall is complete, click “Scan” to scan your computer for any leftover files and click to delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo then restart the computer. After booting, download the latest HP Support Assistant and install.
The latest version at the moment is HP Support Assistant 9.6.714.0 / 8.8.34.31. This version requires Microsoft .NET Framework 4.5 or higher.
