Solving Issue For My Pst File Is Missing In Step Wise Process.
Hey, how to repair if my pst file is missing notify as stepwise method for the easy understanding of the same. Thank you in advance.
Hello, if my pst file is missing kindly follow below steps:
• First you have to exit the outlook and search for the SCANPST.exe file
• Next manually open the pst.exe file on your system
• Now whichever file you want to scan enter its name and then choose browse option to get selected the file.
• Later to begin with the scan click on start option
• Now if there’s any error go for repair option as it fixes them
• Lastly when the repair process is completed start with the outlook and you file is just repaired
