I was trying to download iTunes because I had bought a new iPod. Whenever I try to download it, I get an itunes6464setup exe failed network error. Is it a problem with my system because the internet seems to work fine. I can open other websites. How to solve this?
Solving Itunes6464setup Exe Failed Network Error
Sometimes, some users are unable to download the iTunes installer because of the network error. There are multiple things that can be done in this case. All the solutions are very easy and can be tried by anyone.
The most basic trick is to uncheck the get updates option and try to install iTunes. This has worked in several cases. If this does not work, check your settings. If this also fails, try clearing your browser cache. All things fail, try, and use another browser to download the installer. If even this fails, the chances of all these failures are very small. Try downloading the installer from some direct links if nothing works though.
