Solving Msvcr100 Dll Is Missing
I’m trying to put wamp victimization on a Windows 8 Professional computer in Apache Internet Server after buying the following error message: “The program can not start because the MSVCR100.dll file is missing on your PC to reinstall this program. “In fact, I tried the suggestions on the Internet to get rid of the Visual C ++ distribution and install it, which seems like a mistake.
Where can I get this DLL and which directory should it be? Should I include a more moderate version of the Visual C ++ distribution package, just like the 2012 package? If I am also installing older versions of the distribution package, install one in each article in the online command prompt to remove and install all versions of the Visual C ++ distribution packages; I let in only the 2010er-pack. Most items were associated with Windows 7, not Windows 8. One thing I should do for Windows 8 Professional?
