Solving Teatimer Exe Access Violation
In the past few days, after taking out my laptop from hibernation, I bought the following error message: Access violation at address 00401C55 in the ‘TeaTimer.exe’ module. Write to address 00000001. What exactly is happening here as it shows the teatimer exe access violation?
Answered By 30 points N/A #322300
It’s a lot of security. Because they all benefit from real-time protection, they interfere with each other. You can try to disable other programs to imagine if this is a disadvantage. Otherwise, disable the resident TeaTimer:
– Go to Spybot Mode – Advanced Mode – Tools – Resident.
– Disable the following: Resident “TeaTimer” (protection of all system settings) active.
